Hi Guys,
I am trying to install the emoncmsorg branch on a cloudlinux platform with Cpanel enabled, but I am getting a lot of kick-back from the server ;).
Has anyone tried this before, and if yes, is there a documented procedure you can swing this way please?
Thanks!
Hello @centurionsolar, I would recommend installing the standard emoncms branch for now. The emoncmsorg branch is generally a little behind the main emoncms repo and less well documented. Im working towards bringing the variants together to reduce the work maintaining two variants but this wont likely happen until later in the year due all the other things going on
