This morning after my emonPi’s (was Oct 2019 version) updated mariadb (I have RPI unattended upgrades installed) I found that nothing had been logged for a few hours - after a bit of fiddling around I found that restarting the emoncms_mqtt service go things working again.
Having found that there was a new image available (July 2020) I put that on a new SD card and booted up, setup my own hostnames and imported the data from the previous SD card and then installed the RPI unattended-upgrades package and allowed it to update to the latest packages and when it updated mariadb the system stopped logging any values.
until emoncms_mqtt was restarted the values where not appearing in the ‘Input’ view or in ‘Feeds’.
The emoncms.log shows:
2020-10-22 12:49:35.056|WARN|emoncms_mqtt.php|mysql ping false
2020-10-22 12:56:33.275|WARN|emoncms_mqtt.php|Not connected, retrying connection
2020-10-22 12:56:33.335|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
around the time of the update of mariadb and my restart of emoncms_mqtt
It seems to me that it would be better if emoncms_mqtt retried the connection after a short time or if the enforced restart of mariadb in the update process would restart emoncms_mqtt - is this not possible with the correct systemd configuration of emoncms_mqtt ?
