Hi guys, i will aquire the emonpi and i know it have a local app called emoncms.
First i want to know if is possible create a remote database and connect this local app to this database. If not possible, can i access the local database to manipulate data ?
EmonHub, which is also part of your emonPi software and receives the data from your sensor nodes, will send the data onwards to the local emonCMS, or to a remote emonCMS, or to both. The latest version also has Node-RED and OpenHAB installed - see the [User Guide] (https://guide.openenergymonitor.org).
I saw that Node-Red works like a coding with graphic flows. Can i send informations fromnode-redNode-Red http webservice ?My main interesting is manipulate data and sent to another database.
Yes using HTTP node it’s possible to create a HTTP request to send data to any service using node-red. There are plenty of examples online.
NodeREd is pre-installed on the emonPi with an example to read emonPi power data from MQTT, you can then forward onto any service. Quite a few services have pre-built nodeRED nodes to make posting even easier.
See emonPi nodeRED documentation:
Thanks you very much for explanation. I am live in Brasil, can i buy emonPI from here ? How much is shipping?
Sure, shipping to Brazil is no problem. The shop checkout has a built in shipping cost calculator. Shipping cost is based on weight and service required.
Cool. A last question: i need measure 4 phases (330v) the emonPI can do it?
no, emonpi can only measure single phase AC using clip-on CT sensors
