2017-04-18 17:54:00,764 INFO MainThread EmonHub emonHub 'emon-pi' variant v1.2
2017-04-18 17:54:00,777 INFO MainThread Opening hub...
2017-04-18 17:54:00,780 INFO MainThread Logging level set to DEBUG
2017-04-18 17:54:00,783 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2017-04-18 17:54:00,812 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 9600 bits/s
2017-04-18 17:54:02,817 WARNING MainThread Device communication error - check settings
2017-04-18 17:54:02,820 INFO MainThread Setting RFM2Pi frequency: 868 (8b)
2017-04-18 17:54:03,827 INFO MainThread Setting RFM2Pi group: 210 (210g)
2017-04-18 17:54:04,832 INFO MainThread Setting RFM2Pi quiet: 0 (0q)
2017-04-18 17:54:05,836 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2017-04-18 17:54:06,841 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
2017-04-18 17:54:07,846 DEBUG MainThread Setting RFM2Pi subchannels: ['ToRFM12']
2017-04-18 17:54:07,849 DEBUG MainThread Interfacer: Subscribed to channel' : ToRFM12
2017-04-18 17:54:07,852 DEBUG MainThread Setting RFM2Pi interval: 10
2017-04-18 17:54:07,855 DEBUG MainThread Interfacer: Subscribed to channel' : ToRFM12
2017-04-18 17:54:07,957 DEBUG MainThread Setting RFM2Pi pubchannels: ['ToEmonCMS']
2017-04-18 17:54:07,960 DEBUG MainThread Interfacer: Subscribed to channel' : ToRFM12
2017-04-18 17:54:08,031 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2017-04-18 17:54:08,035 INFO MainThread MQTT Init mqtt_host=127.0.0.1 mqtt_port=1883 mqtt_user=emonpi
2017-04-18 17:54:08,104 DEBUG MainThread MQTT Subscribed to channel' : ToEmonCMS
2017-04-18 17:54:08,198 DEBUG RFM2Pi RFM2Pi broadcasting time: 17:54
2017-04-18 17:54:08,257 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2017-04-18 17:54:08,275 DEBUG MainThread emoncmsorg Subscribed to channel' : ToEmonCMS
2017-04-18 17:54:08,450 INFO MQTT Connecting to MQTT Server
2017-04-18 17:54:08,602 INFO MQTT Could not connect...
2017-04-18 17:54:09,761 INFO MQTT Connecting to MQTT Server
2017-04-18 17:54:09,854 INFO MQTT Could not connect...
2017-04-18 17:54:10,972 INFO MQTT Connecting to MQTT Server
2017-04-18 17:54:11,070 INFO MQTT Could not connect...
2017-04-18 17:54:12,188 INFO MQTT Connecting to MQTT Server
2017-04-18 17:54:12,208 INFO MQTT Could not connect...
2017-04-18 17:54:13,331 INFO MQTT Connecting to MQTT Server
2017-04-18 17:54:13,358 INFO MQTT Could not connect...
2017-04-18 17:54:21,419 DEBUG RFM2Pi RFM2Pi broadcasting time: 17:54
2017-04-18 17:54:22,053 INFO MQTT Connecting to MQTT Server
2017-04-18 17:54:22,059 INFO MQTT Could not connect...
2017-04-18 17:54:23,163 INFO MQTT Connecting to MQTT Server
2017-04-18 17:54:23,169 INFO MQTT Could not connect...
2017-04-18 17:54:24,288 INFO MQTT Connecting to MQTT Server
2017-04-18 17:54:24,306 INFO MQTT Could not connect...
2017-04-18 17:54:25,441 INFO MQTT Connecting to MQTT Server
2017-04-18 17:54:25,465 INFO MQTT Could not connect...
2017-04-18 17:54:26,569 INFO MQTT Connecting to MQTT Server
2017-04-18 17:54:26,585 INFO MQTT Could not connect...
2017-04-18 17:54:27,689 INFO MQTT Connecting to MQTT Server
2017-04-18 17:54:27,741 INFO MQTT Could not connect...
2017-04-18 17:54:28,872 INFO MQTT Connecting to MQTT Server
2017-04-18 17:54:28,959 INFO MQTT Could not connect...
2017-04-18 17:54:30,125 INFO MQTT Connecting to MQTT Server
2017-04-18 17:54:30,229 INFO MQTT Could not connect...
2017-04-18 17:54:31,381 INFO MQTT Connecting to MQTT Server
2017-04-18 17:54:31,439 INFO MQTT Could not connect...
2017-04-18 17:54:31,519 DEBUG RFM2Pi RFM2Pi broadcasting time: 17:54
2017-04-18 17:54:32,555 INFO MQTT Connecting to MQTT Server
2017-04-18 17:54:32,611 INFO MQTT Could not connect...
2017-04-18 17:54:33,759 INFO MQTT Connecting to MQTT Server
2017-04-18 17:54:33,840 INFO MQTT connection status: Connection successful
2017-04-18 17:54:33,844 DEBUG MQTT CONACK => Return code: 0
2017-04-18 17:54:34,030 INFO MQTT on_subscribe
2017-04-18 17:54:38,340 INFO emoncmsorg sending: https://emoncms.org/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[]&sentat=1492538078
2017-04-18 17:54:38,924 DEBUG emoncmsorg acknowledged receipt with 'ok' from https://emoncms.org
2017-04-18 17:54:38,927 INFO emoncmsorg sending: https://emoncms.org/myip/set.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y
2017-04-18 17:54:41,521 DEBUG RFM2Pi RFM2Pi broadcasting time: 17:54
2017-04-18 17:54:51,589 DEBUG RFM2Pi RFM2Pi broadcasting time: 17:54
2017-04-18 17:55:01,654 DEBUG RFM2Pi RFM2Pi broadcasting time: 17:55
