Emoncms interface into Raspbian jessie Lite
Hi! I have the pre built image installed into my RPi and supposedly working, since my localhost server is running (i was able to dowload a html file). But, once raspbian Lite does not have graphical interface, how can i access Emoncms via terminal? Or there is another way to “broswer” into my localserver?
If you got an HTML file I presume you have the IP address in which case just add emoncms e.g. xxx.xxx.xxx.xxx/emoncms should give you a login page. You need to register the first user and that user is then the ‘admin’ account. HTH
