Emoncms impulse counting
Hello all,
I try to measure the amount of rain. Impulses are send from a device using 8266. Emoncms is accumulating. Everything works fine but somtimes impulse are not counted correctly (missing). What are the correct settings in this case?
Thanks for Your help
Uwe
Welcome.
What do you mean by ‘missing’?
How have you set up the input processing? As the data will be irregular, you need to use the PHPTIMESERIES Engine to store the data.
