I ask if is possible install emoncms on a linux hosted server, because i try to install it without success (some error abaut redis and with dashboard module)
Hello @Stefano_Truzzi yes this is possible, that’s how it is designed to work, I would recommend using our installation scripts to install all the related dependencies GitHub - openenergymonitor/EmonScripts: Emoncms Stack Installation and Update scripts (though not to be used if your server has other things running on it already as it may break the configuration for the other applications)
Thanks, I think that my hosted server don’t permit to use script…I will ask to Aruba about that.
