Done. I also changed ‘Account’ in most places to ‘Konto’ (still ambiguous about it).
But there is one additional string which does not appear in the strings.xml. It says: ‘Add at least one acoount to proceed’ and comes when the Settings menu is left without any account defined.
running Android 4.3, latest it can have … what you can call a good
old-timer but according data this version is still 10% of the droid users …
plus it is a rather small screen compared to today’s models that are more
fablets then tels though yours is smaller
must be relted to droid version, THE big problem in the Android world, to
many different versions and not all compatible … in a few years it will be
better when those old-timers will be gone
I have also noticed it is no longer possible to switch between accounts on the app since updating. selecting another account just results in a black screen. If I then exit the app and reopen it the newly selected account is populated but changing back or to another account results in the same blank page. Anyone else seeing this? I haven’t had any time to look into it yet.
The font size was increased in version V2.0.6 to try and make the Power Now and Today figures more readable at a glance. Especially on wall mounted tablets. Even on my 4.5" Moto G 2013 the font size does not look overly large to me, see my post above for screen shot.
This is what the cost screen looks like for me, again I don’t think it’s overly large:
I think there is a separate issue here with the formatting on different devices. On my devices the units are displayed in a much smaller font, in @bidouilleur and @Paul screenshots the units (/h) are displayed in the same size font.
@Paul does the problem go away if you select some feeds to display and set a unit cost? What version are you running? It’s strange that the ‘H’ character is missing from ‘3H’ and ‘6H’ view. The version number is now shown on the settings page.
If I set-up 2 or 3 pages, for example ‘Solar’, ‘Usage’ & 'Diverted, allocate the feeds in settings etc, so everything looks fine - graph & barchart display OK ect.
BUT, if I close all running apps (via the android app switcher), and then restart emoncms, all of my settings will be lost, and I need to set up the feeds etc from scratch again. Ggrr!
I think that maybe a recent “feature” now you mention it, I had set up several pages for each account (8+ pages per 6 accounts). I DO recall deleting some accounts to access the settings that are squeezed off the settings page, But I have NO recollection of deleting the pages out of the remaining accounts, but they are no longer there!!! I thought I was losing my marbles (please don’t say I cannot lose that what was already lost years ago!) so glad I didn’t spend the afternoon rebuilding!!!
I have also noticed a situation where a named account appears with it’s “emoncmsX” alias shown in the title bar instead, the last time I saw this happen I happened to rotate the phone as I did a double take as saw the “emoncmsX” change to the name I had given it.
i have some of the same problems. The font for the current values is just too big on my phone as well (ascend p7 running android 5.1) not sure what’s it’s resolution nor what the dpi is.
Also after opening my app just now all the pages i had created in the previous version are gone somehow. I can make screenshots if needed.
Might the problems come from dpi and resolution used on phones ? as not all phones have the same resolution nor dpi i guess but i have no clue how the dpi stuff works on android i know on windows this can produce such effects but changing dpi scales the app controls and fonts perhaps something similar is happening here ?
I also had a second account set up for testing against emoncms.org when selecting that using the drop down menu all i get is an empty page
it seems to me that it sometimes displays correctly and sometimes not, it seems to mess up switching between the multiple accounts using the drop menu to switch accounts.
I created a video using game screen recorder (that recorded my desktop on android). I keep trying a few things, readd some settings even whipe the app data as i figured i would have to recreate everything again eventually.
Could the losing the settings be related to the custom currency setting ? perhaps if it is / was missing (as it did not exist in a previous version) it could not load the pages again ?
here’s the youtube video i only started the app a second time after 2.0.6 update. if you take the time looking throught the whole 7 minutes of me messing about you’ll notice that sometimes it does display correctly like after i added the account again it displayed correctly initially but after adding a second account it messed up again.
Also it seems the “add at least one account to proceed” text is not translated to dutch or is not able to be translated
edit: i know my api keys are visible at some point, but it’s a local installation plus i added some bluring on the youtube video using youtube editor but it seems to take some time to process it, it’s currently only at 26% so normally once it has done it should be hidden so i don’t mind
sp
Scale-independent Pixels - this is like the dp unit, but it is also scaled by the user’s font size preference. It is recommended you use this unit when specifying font sizes, so they will be adjusted for both the screen density and user’s preference.
However it seems like it is not working correctly across all devices. It is possible to set different dimensions for different screen sizes, so I’ll try this to get a bigger output on tablets, and revert the font size on phones.
As reported by @joyrider3774 there is one final string to be translated:
See issue:
@tamsin has now made the string translatable and I’ve just committed a translation using Google translate, any chance @bidouilleur, @joyrider3774 and @gab.lau could proof read it and submit a PR to tweak if needed. Thanks
@tamsin has committed a change to make the font smaller on phones and larger on tablets. Looks great to me. However, I could never recreate the text overflowing issues on my Nexus devices
I will be pushing a V2.0.8 beta update to Google Play this evening which includes this update and fixes for the loosing pages issues and some extra translated strings. Please could you test and report back. Thanks!
@glyn.hudson dutch translation is correct, don’t know about the other languages.
I’ll check tommorow for the new version as i will have to recreate my 8 or was it 9 my electric pages again.
Btw was it ever determined what the cause was of loosing the pages ? my guess was that the new currency setting as that did not exist in the previous version.
if that’s the cause, what if for any reason another setting gets added in the future wouldn’t the same problem happen again then ?
