I have an EmonBase and yesterday I reimaged the SD card with emonSD-30Oct18 (Stable). This causes the Pi to lock up on boot. I guess the hardware (maybe this is a Pi2? I don’t know) is not supported.
So I had to reimage it with ( emonSD-26Oct17).
This works, boots, and I’m able to complete setup. I was immediately able to see my data being received. I did an Adminstration → Update and it completed without erorrs.
However, every time I reboot the Pi, it does not collect any data.
In Administration → Server information
I see mosquitto and emoncms_mqtt as failed/not running.
The only thing logged is:
2019-02-20 16:47:51.478|ERROR|feedwriter.php|Starting feedwriter script
Then nothing logged after that.
After quite a bit of fiddling around I was able to get it working again by running the following commands:
systemctl start mosquitto.service
systemctl start emoncms_mqtt
I need to do this every boot or it does not collect any data.
Any suggestions on how to automate this?
I have tried enabling the services but they are already enabled.
I did not run the EmonPi update, I only ran the EmonBase update. This is because I have an EmonBase (not EmonPi). So I’m not going to run that unless I need to or I missed something in the documentation.=
