Hi, I’ve been running an Emon system for a little over a year with no major problems. The system consists of an EmonTx, three EmonTH and an EmonBase, the latter is on a UPS.
The only funny is there are now five non existent nodes shown in the inputs and feed screens, I think the last one, labelled ‘3phase’ appeared after the EmonTx suffered a power glitch.
At the end of every month I run a backup and update the firmware. This month the backup does not run, The log window shows last months backup as it completed, I click the backup button and all it does is blink and show last months back again. It usually runs through the backup process, which takes several minutes, then I can refresh and download it. Any suggestions please ??
If some-one can tell me how, I can post the system details.
Hi, thanks for your reply. I assume by the log window you mean the window below the ‘create backup’ button ? This shows last months (5 July) successfully completed backup. When I click the backup button it just clears briefly, then shows the same. It used to clear and show the progress of the current backup, which used to take several minutes to complete.
