Hello,
I am attaching two temp probes to an RJ45 terminal breakout board.
I have noticed the probs are reporting temps on Temp1 and Temp2. When I wire up a second RJ45 terminal breakout board and connect it the same as before, the order in which they take temp 1 and temp 2 vary so what would have been temp 1 in the first setup, is temp2 in the other one.
Are they random?
This is how it’s wired, can I make it consistent and reliable? id ideally like to wire up all my TX’s to breakout boards in a way I know what will be what when I deploy.
