Hi, I’m a NOOB at OpenEneregyMonitor. I’ve just brought & Installed an emonPi Energy Monitor - Solar PV Bundle + a Temperature sensor. I believe I have the CT reading correctly by following the relevant how-to section. My “Inputs” page has emonpi listed with inputs power1, power2, power1pluspower2, vrms and t1 through t6. t1 reads approx 18.3, which given where the temperature sensor is, is believable.
I have just the one temperature sensor. I don’t believe its readings are being logged to a feed.
Clicking on the Spanner icon next to t1 brings up a dialog box with
You have no processes defined
Add process: [log][kwh][+inp]
Log to Feed. Data:Realtime. Feed:CreateNew. emonpi:t1. Engine: PHPFINA Fixed Interval: 10s [ADD]
Is logging it as simple as pressing the add button? I’m concerned though about the [kwh] on the add process line.
I’ve looked for a “How to log temperatures” section and haven’t found it. Do temperatures show up on any of the graphs?
Any help would be appreciated.
As I said, I’m new to emoncms & openenergymonitor, but I’m an experienced computer, linux & raspberry pi user.
Thanks in advance.
Steve
