Hi. For some reason my emonpi crashed & I didn’t notice it for 3 days. I’m not worried about why it crashed, but looking at my data, the solar and usage show as non-zero flat lines for the period in the MySolar app.
Is the app extrapolating with Zero consumption and generation recorded,
or is emoncms assuming a flat non-zero generation and consumption for that period? If so, do I need to edit my data? If so, how?
Hopefully, a screenshot of the app graph is attached.
It’s actually doing two different things, when you look at the power data in the window it is assuming a non zero value. The kWh data however shown on the history page does not increment energy use if the gap in data is more than 2 hours - it will otherwise assume power was consumed at the last known rate for the period <2h. In your case with a much larger gap it should not have assumed energy use/production…
If you look at the same data using the Graph view and click show missing’ do you see a big gap or is there data present?
Ok thanks, that confirms the data is missing as expected which will mean that your cumulative kWh values will not have registered energy consumption for that period.
