How does one change the default email behavior?, based on a specific users input email event ?, the input description mention that this is possible, I change the default_email in the default-settings.ini and email is working and receive the " Emoncms Alerts" based on the trigger. I need to change the default behavior to mail the registered user using the users email address based on registration. Will this be possible?
default_emailto = ''[email protected]"
Send an email to the user with the specified body. Email sent to user’s email address or default set in config.
Supported template tags to customize body: {type}, {id}, {key}, {name}, {node}, {time}, {value}
Example body text: At {time} your {type} from {node} with key {key} named {name} had value {value}.
Output: Does NOT modify value passed onto next process step.
Thanks in advance.
