Deleting the openevse from Demandshaper removed my feeds - only realised just now so have restored them using the cog (which also put it back in demandshaper - but I’ve ensured the ‘off’ is set).
JSON below …
{"mode":"STA","wifi_client_connected":1,"eth_connected":0,"net_connected":1,"ipaddress":"192.168.1.10","emoncms_connected":1,"packets_sent":30702,"packets_success":30511,"mqtt_connected":1,"ohm_hour":"NotConnected","free_heap":159780,"comm_sent":1674291,"comm_success":1674266,"rapi_connected":1,"evse_connected":1,"amp":0,"voltage":239.47,"pilot":32,"wh":491674,"temp":260,"temp1":260,"temp2":false,"temp3":false,"temp4":false,"state":254,"vehicle":0,"colour":5,"manual_override":0,"freeram":159780,"divertmode":1,"srssi":-74,"elapsed":9151,"wattsec":6.167148e7,"watthour":491674,"gfcicount":0,"nogndcount":0,"stuckcount":0,"solar":0,"grid_ie":6,"charge_rate":6,"divert_update":9,"ota_update":0,"time":"2021-06-10T09:55:28Z","offset":"+0000"}
{"firmware":"7.1.3.EU","protocol":"-","espflash":4194304,"version":"4.0.1","diodet":0,"gfcit":0,"groundt":0,"relayt":0,"ventt":0,"tempt":0,"service":2,"scale":0,"offset":0,"mqtt_supported_protocols":["mqtt","mqtts"],"http_supported_protocols":["http","https"],"ssid":"Pantry","pass":"_DUMMY_PASSWORD","www_username":"greentangerine","www_password":"_DUMMY_PASSWORD","hostname":"openevse-2d71","sntp_hostname":"pool.ntp.org","time_zone":"Europe/London|GMT0BST,M3.5.0/1,M10.5.0","emoncms_server":"https://emoncms.org","emoncms_node":"openevse","emoncms_apikey":"_DUMMY_PASSWORD","emoncms_fingerprint":"","mqtt_server":"192.168.1.84","mqtt_port":1883,"mqtt_topic":"emon/openevse","mqtt_user":"emonpi","mqtt_pass":"_DUMMY_PASSWORD","mqtt_solar":"","mqtt_grid_ie":"emon/emontx3cm16/P3","mqtt_vrms":"emon/emontx3cm15/Vrms","mqtt_announce_topic":"openevse/announce/2d71","ohm":"","divert_PV_ratio":1.1,"divert_attack_smoothing_factor":0.4,"divert_decay_smoothing_factor":0.05,"divert_min_charge_time":300,"tesla_username":"","tesla_password":"","tesla_vehidx":-1,"led_brightness":128,"flags":523,"emoncms_enabled":true,"mqtt_enabled":true,"mqtt_reject_unauthorized":true,"ohm_enabled":false,"sntp_enabled":true,"tesla_enabled":false,"divert_enabled":true,"pause_uses_disabled":false,"mqtt_protocol":"mqtt","charge_mode":"fast"}
