Easiest way to use emonPi data in a Windows install of emonCMS
The topic says it all :slight_smile:
I would rather not install & enable Redis on the Windows install (but I guess I will if I have to)
I managed to install the Backup and the Sync module but both of them require Redis.
I managed to transfer the .dat and .meta files from the emonPi in the right place but I guess I would needthe database feed data as well… before I go there, is there a not-too-painful way to bring feed data into a Windows install of emonCMS, to analyze it using the Graph module?
Thanks!
Franck
So many parts of emoncms are becoming Linux specific, especially around the admin page and anything running as a service (mqtt_input,feedwriter, service-runner etc). So if I were cornered into installing emoncms on a windows box, I would install VM software and then install emoncms in a Linux VM, not so helpful if you already have a WAMP sever running I guess.
Yeah, I thought about that option… this may be the easiest route indeed.
Thanks!
. . . or docker perhaps?
I’ve not used docker on windows or the emoncms docker install, just throwing it out there!
