sunsetdk
(René Jensen)
7 July 2020 21:51
#1
Hi
Im trying to setup EMONCMS on my synology using Docker. I can it it running using the prod addon script for docker-compose.
I get the webpage. I can login (after creating my local user). Pressing new device/input yields nothing. Absolutely nothing happens when i press the button.
Any hints would be appreciated.
René
borpin
(Brian Orpin)
8 July 2020 07:32
#2
How are you feeding the data to emoncms?
sunsetdk
(René Jensen)
8 July 2020 07:38
#3
I did try but i get this error:
Requested feed does not exist feedid=0
When i go to the feeds it tell me i have to create a input, and this it where im stuck.
borpin
(Brian Orpin)
8 July 2020 08:30
#4
How are you sending data to emoncms? MQTT? HTTP? It doesn’t arrive by magic
Do you see anything on the Inputs page?
sunsetdk
(René Jensen)
8 July 2020 08:56
#5
Node Red.
But don’t i need do create somewhere for the data to go (input/device)
borpin
(Brian Orpin)
8 July 2020 09:30
#6
No it will just appear on the Input page. This is effectively a “This is the data I can see do you want to log it” page.
How are you sending it from Node-Red? emoncms node, MQTT, HTTP?
sunsetdk
(René Jensen)
8 July 2020 09:39
#7
Emoncms node.
Im only testing at the moment.
i use a inject node to set
msg.payload = 250
msg.topic = water
I have set feedid to “water” in the ecomcms node.
Injet “works”, but yields an error in the log.
2020-07-08 09:37:36.060|WARN|feed_model.php|Feed model: Requested feed does not exist feedid=0
I setup the docker on my syno. Created a user and then press innject in nodeRed. i did not setup in Emoncms at all.
borpin
(Brian Orpin)
8 July 2020 09:57
#8
Well clearly it doesn’t work!
Are you sending that by MQTT to the same broker the emoncms instance is pointing to?
sunsetdk
(René Jensen)
8 July 2020 10:01
#9
I not using MQTT but the emoncms node. The node is setup pointing to the IP and the port of my emoncms server.
borpin
(Brian Orpin)
8 July 2020 10:04
#10
You added a Write API key?
Ok. Does it give a green dot at the bottom?
That format is not JSON so if you selected JSON it will not work. Have a look at the info pane for the data format.
sunsetdk
(René Jensen)
8 July 2020 10:09
#11
I did add the API key. If i change the API key to something wrong i get a different error. So API key must therefore be correct.
Should the data be json data? If so can you show me a quick example which should work?
In my inject node data types are for the topic = string and payload = number.
No i don’t get the green dot
borpin
(Brian Orpin)
8 July 2020 10:12
#12
Look at the info tab for the node!
best use Valid JSON.
sunsetdk
(René Jensen)
8 July 2020 10:20
#13
I appreciate the help.
The problem was me
I used the wrong node. I used the emoncms in rather than the emoncms out node. Thanks for the screenshot, that is what let me to the correct path.
