back again with more problem, bms start ok, nothing connected to bms, only bms connected to pc, i can not save any settings from web but on serial i have following error. can not anyone else had this issue in the past either under rules i have Internal BMS error.
i m trying to enable avr programming mode but without any luck
[I][tft.cpp:388] tftwakeup_task(): Wake up screen
[I][Rules.cpp:142] SetError(): Set error 4
No, doesn’t help.
I can putty from my local windows to the remote cerboGX device
Then I make a socks tunnel to that cerbo in the putty settings.
After this I set the proxy on the browser of my local machine to the forwarded socks port.
Then I can surf all webpages all over the world including youtube and other content through this socks proxy running on the remote cerbo.
Also this lines I write here are tunneled through this socks proxy.
But when I enter the IP address of the DIYBMS only the blue ring is coming like shown above.
The other day I cloned latest diyBMS-CurrentShunt github repo and set about creating an order with JLCPCB using the repo gerbers/bom/cpl files. After placing the order I received this response from JLCPCB:
So sorry about that the maximum plated holes we can make is 6.3mm, those big plated holes in your file are out of our capabilities, if proceed with this order ,the quality of those big plated holes will not be promised (e.g. defects may highly occur: un-plated holes, incomplete plating, hole with copper residues etc.). Can you accept that and no quality compliant about these issue? If yes, we can proceed with this order .
Just had a look at the properties for the ‘Murata 3020-01101-0’ footprint (‘3D Settings’ tab) in kicad and the way it renders sure does make it look like the slots are plated …even though they are not.
Both oval slots have a pad type of ‘NPTH, Mechanical’ which makes the hole look like it’s plated though of course they are ‘Non Plated Through Hole’ (NPTH).
If I change the slots to have a pad type of just ‘Through-hole’ they do look better but the measuring tool shows them as 7mm wide even though the hole size is 5mm. I think this is because of the footprint pad clearance setting …just haven’t been able to change that as yet …not even sure I should.
Regardless, the original order has been cancelled so I’ll figure something out eventually …I may just re-submit and try and get JLCPCB to understand the holes are only 5mm and not plated at all.
Edit: I have since re-submitted the original gerber (et al) files with a note advising the holes are NPTH. The order has since been approved and production is underway …guess I just got ‘lucky’ on the first attempt
So i have the controller with esp32, been using for a test project with 7s20p packs. I notice there are 4 relays on the board, 2 are mechanical relays (been using them for turn on fan and battery disconnect when voltage drop too low) and there are relay 3 and 4. I wonder what can i use them with and what kind of relay are they, how they operate. Thanks Stuart, your project work excellent and i love them
Relays 3 and 4 are electronic relays. You can use them like other mechanical relays, however they only handle a much lower current (from memory 1amp) so check the data sheet for the details.
Thanks @stuart for the firmware upgrade and bug fixes this week!
My controller has not rebooted since and time is displayed correctly after the “one day” mark too!
Now for me to get working on finishing my powerwall and cabinets
Today my CERBO has arrived, I am eager to test it on the test bench, but wait for other Shunts from China to arrive (I hope it will not be long) because the one that is operative is already installed in the installation and I do not want to disassemble it for tests.
