Hi all, just wondering if anybody has rewrote the DIYBMS software to work with mySQL or has anybody wrote a script that reads influxdb data and populates a mySQL database?
Really can not be bothered learning influxdb or mqtt.
Any recomendations for a replacement BMS that does support mySQL?
If you run mySQL i highly recommend you to install Node-red and Mosquitto. If you do that its very simple to get the data in with like 3 nodes and your done
Thank you, will have to look at node-red. For the moment i setup influxdb which seems very similar to mysql so far, but i am yet to build a front end for it, dont like grafana.
