Hi
I have error Discarded RX frame ‘string to short’
can someone give me a idea to what is wrong with my settings, my Emonhub settings is like below
####################### emonhub.conf #########################
### http://github.com/openenergymonitor/emonhub/blob/emon-pi/configuration.md
####################### emonHub settings #######################
[hub]
loglevel = DEBUG
# use_syslog = yes
####################### Interfacers #######################
[interfacers]
[[SerialTx3e]]
Type = EmonHubTx3eInterfacer
[[[init_settings]]]
# Un-comment line below if using RS485 adapter
#com_port = /dev/ttyRS485-0
# default com port if using USB to UART adapter
# com_port= /dev/ttyUSB0
com_port= /dev/ttyAMA0
com_baud = 115200
[[[runtimesettings]]]
pubchannels = ToEmonCMS,
nodeoffset = 8
group = 210
frequency = 433
baseid = 10 # emonPi / emonBase nodeID
quiet = true # Report incomplete RF packets (no implemented on emonPi)
calibration = 230V # (UK/EU: 230V, US: 110V)
# interval = 0 # Interval to transmit time to emonGLCD (seconds)
[[MQTT]]
Type = EmonHubMqttInterfacer
[[[init_settings]]]
mqtt_host = 127.0.0.1
mqtt_port = 1883
mqtt_user = emonpi
mqtt_passwd = emonpimqtt2016
pubchannels = ToRFM12,
subchannels = ToEmonCMS,
node_format_enable = 1
# emonhub/rx/10/values format
nodevar_format_enable = 1
[[SunTech Power]]
[[[init_settings]]]
url = https://emoncms.org
apikey = 1xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx64
senddata = 1 # Enable sending data to Emoncms.org
sendstatus = 1 # Enable sending WAN IP to Emoncms.org MyIP > https://emoncms.org/myip/list
sendinterval= 5 # Bulk send interval to Emoncms.org in seconds
####################### Nodes #######################
[nodes]
## See config user guide: http://github.com/openenergymonitor/emonhub/blob/master/configuration.md
[[8]]
nodename = emonTx_3
firmware =V2_3_emonTxV3_4_DiscreteSampling
hardware = emonTx_(NodeID_DIP_Switch1:OFF)
[[[rx]]]
names = Electric fan, Computer, power13, power14, temp1, temp2, temp3, temp4, temp5, temp6, pulse
datacode = 0
units =W,W,W,W,V,C,C,C,C,C,C,p
