pb66
(Paul)
3
You can check the kernel version on the admin page of emoncms or using uname -r at the command prompt of other (non-emoncms server) Pi’s. The patch is applied from 4.4.26-v7+.
Although apparently just
sudo apt-get update
sudo apt-get dist-upgrade
will do, the official advice from the foundation is to use
sudo apt-get update
sudo apt-get install raspberrypi-kernel
…AND REBOOT!!
The new kernel will not get loaded until it is restarted.
This assumes a Raspbian OS image, I haven’t looked into any others.
