Deleting erroneous data
My monitor had been cabled the wrong way around which is now resolved and the data looks good. However, I’d like to now capture all the erroneous data from before 15:00 today
Is this something I can do myself?
Mike
Welcome, Mike, to the OEM forum.
I’m not sure what your problem is from such few words, so I’ve got to make many assumptions. All I know is, you’re using emonCMS. I have no indication what you’re monitoring.
The first observation is, if you have not “logged” your data to a Feed, it has gone forever. If you have logged the data (i.e. you can see it on a dashboard or a graph) then it has been saved and you might be able to “Post-process” the data to correct it.
I think you’ve got a lot of learning ahead. I know it’s a steep curve, because we’ve all been there and done it. Don’t be afraid to ask, unlike a forum I could (and won’t name), nobody here will bit your head off for asking a “silly” question, because it probably isn’t silly at all.
You might find the FAQ, and what information we need to help you and how to ask for help, is a good starting point. After that, head for the “Docs” section but take it slowly, there’s a huge amount of information in there and it will take months to even get to know where everything is.
Hi Mike,
Your old data has been removed. Nice work fixing the connection issue :+1:
Have you considered submitting your system https://heatpumpmonitor.org/ ?
Thanks all
I just added it to the heatpumpmonitor.org page now as well
Mike
