The log is below. Was it working before? Yes and no. The inputs were there and I could add feeds but no data ever actually appeared. The values always read as “NaN” or “null.” I’ve tried updating. That caused some issues. After updating, for example, the next “sudo apt-get update” would freeze at around 45%.
I’ve tried lots of fiddling. Eventually I downloaded the latest image (same image that it came with) and rewrote the memory card. Now no inputs are listed at all.
Log:
2017-04-16 20:39:59,377 INFO MQTT connection status: Connection successful
2017-04-16 20:39:59,379 DEBUG MQTT CONACK => Return code: 0
2017-04-16 20:39:59,480 INFO MQTT on_subscribe
2017-04-16 20:56:03,563 DEBUG MainThread SIGINT received.
2017-04-16 20:56:03,564 INFO MainThread Exiting hub...
2017-04-16 20:56:03,662 INFO MainThread Exit completed
2017-04-16 20:56:56,748 INFO MainThread EmonHub emonHub 'emon-pi' variant v1.2
2017-04-16 20:56:56,749 INFO MainThread Opening hub...
2017-04-16 20:56:56,750 INFO MainThread Logging level set to DEBUG
2017-04-16 20:56:56,750 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2017-04-16 20:56:56,753 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2017-04-16 20:56:58,756 WARNING MainThread Device communication error - check settings
2017-04-16 20:56:58,758 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2017-04-16 20:56:59,760 INFO MainThread Setting RFM2Pi group: 210 (210g)
2017-04-16 20:57:00,762 INFO MainThread Setting RFM2Pi quiet: 0 (0q)
2017-04-16 20:57:01,764 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2017-04-16 20:57:02,766 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
2017-04-16 20:57:03,769 DEBUG MainThread Setting RFM2Pi subchannels: ['ToRFM12']
2017-04-16 20:57:03,770 DEBUG MainThread Interfacer: Subscribed to channel' : ToRFM12
2017-04-16 20:57:03,771 DEBUG MainThread Setting RFM2Pi pubchannels: ['ToEmonCMS']
2017-04-16 20:57:03,771 DEBUG MainThread Interfacer: Subscribed to channel' : ToRFM12
2017-04-16 20:57:03,773 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2017-04-16 20:57:03,774 INFO MainThread MQTT Init mqtt_host=127.0.0.1 mqtt_port=1883 mqtt_user=emonpi
2017-04-16 20:57:03,777 DEBUG MainThread MQTT Subscribed to channel' : ToEmonCMS
2017-04-16 20:57:03,778 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2017-04-16 20:57:03,780 DEBUG MainThread emoncmsorg Subscribed to channel' : ToEmonCMS
2017-04-16 20:57:03,878 INFO MQTT Connecting to MQTT Server
2017-04-16 20:57:03,881 INFO MQTT connection status: Connection successful
2017-04-16 20:57:03,882 DEBUG MQTT CONACK => Return code: 0
2017-04-16 20:57:03,984 INFO MQTT on_subscribe
UPDATE:
I did an update from the web interface and now the log is different:
Log:
2017-04-16 20:50:22,857 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2017-04-16 20:50:24,861 WARNING MainThread Device communication error - check settings
2017-04-16 20:50:24,862 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2017-04-16 20:50:25,864 INFO MainThread Setting RFM2Pi group: 210 (210g)
2017-04-16 20:50:26,866 INFO MainThread Setting RFM2Pi quiet: 0 (0q)
2017-04-16 20:50:27,869 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2017-04-16 20:50:29,491 INFO MainThread EmonHub emonHub 'emon-pi' variant v1.2
2017-04-16 20:50:29,492 INFO MainThread Opening hub...
2017-04-16 20:50:29,493 INFO MainThread Logging level set to DEBUG
2017-04-16 20:50:29,494 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2017-04-16 20:50:29,497 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2017-04-16 20:50:31,500 WARNING MainThread Device communication error - check settings
2017-04-16 20:50:31,501 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2017-04-16 20:50:32,503 INFO MainThread Setting RFM2Pi group: 210 (210g)
2017-04-16 20:50:33,505 INFO MainThread Setting RFM2Pi quiet: 0 (0q)
2017-04-16 20:50:34,507 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2017-04-16 20:50:35,510 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
2017-04-16 20:50:36,512 DEBUG MainThread Setting RFM2Pi subchannels: ['ToRFM12']
2017-04-16 20:50:36,513 DEBUG MainThread Interfacer: Subscribed to channel' : ToRFM12
2017-04-16 20:50:36,514 DEBUG MainThread Setting RFM2Pi pubchannels: ['ToEmonCMS']
2017-04-16 20:50:36,515 DEBUG MainThread Interfacer: Subscribed to channel' : ToRFM12
2017-04-16 20:50:36,516 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2017-04-16 20:50:36,517 INFO MainThread MQTT Init mqtt_host=127.0.0.1 mqtt_port=1883 mqtt_user=emonpi
2017-04-16 20:50:36,520 DEBUG MainThread MQTT Subscribed to channel' : ToEmonCMS
2017-04-16 20:50:36,521 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2017-04-16 20:50:36,523 DEBUG MainThread emoncmsorg Subscribed to channel' : ToEmonCMS
2017-04-16 20:50:36,621 INFO MQTT Connecting to MQTT Server
2017-04-16 20:50:36,624 INFO MQTT connection status: Connection successful
2017-04-16 20:50:36,625 DEBUG MQTT CONACK => Return code: 0
2017-04-16 20:50:36,727 INFO MQTT on_subscribe
