Hi
i got a Problem with one of my EmonTx. As i tried to calibrate and update the EmonTx Firmware to a 3-phase System, i got strange readings on the CT3 port. I am using the Arduino IDE and the 3-phase example sketch. In my first attempts i used a 2.3 kW water boiler to get some readings, so the current should be at 9-10 A. For this test i connected every CT on the same line, so the current should be the same. However every time i start up the EmonTx (restarting the serial monitor in the Arduino IDE) the current on CT3 is at 130A and falls to 1.5-0.5A after a while. Only when i connect CT1 and CT2 as well, this malfunction doesn’t appear but then readings on CT3 are still wrong. (5A at CT3 and 9A at CT1 and CT2)
I made 3 measurements:File-Upload.net - Datei nicht gefunden
Measurement 1: only CT1 and CT3 are connected
Measurement 2: CT1, CT2 and CT3 connected
Measurement 3: CT3 and CT4 connected, water boiler turned off and on in between
With the second EmonTx i bought, it works perfectly well. So i assume this must be an hardware issue.
My question is now, is there a defect on the CT3 port and do i have to get a new EmonTx?
Or do i just have to always use CT1 and CT2 as well for my measurement? Then i would calibrate the CT3 port so that it would meet the 9A readings of the other CTs, but i dont know if there will be a problem when i go to higher loads.
(Sorry for the file-upload link, i dont know how to activate the file attachment for new users)
