ian
(ian)
21
I am not clear. Can you already connect via Dataplicity?
johnbanks
(John Banks)
22
Hi …
I can connect to & use the dataplicity terminal where you enter su pi and the password.
However when I use Wormhole which takes you to the emonCMS login, it locks up - see my post in this thread 3 or 4 up.
Thx for yr response
ian
(ian)
23
Hi
I don’t use Wormhole. My problem was that I could not get Dataplicity to connect.
However this is my supervisord.conf
; supervisor config file
[unix_http_server]
file=/var/run/supervisor.sock ; (the path to the socket file)
chmod=0700 ; sockef file mode (default 0700)
[supervisord]
logfile=/var/log/supervisord.log ; (main log file;default $CWD/supervisord.log)
pidfile=/var/run/supervisord.pid ; (supervisord pidfile;default supervisord.pid)
childlogdir=/var/log/supervisor ; (‘AUTO’ child log dir, default $TEMP)
; the below section must remain in the config file for RPC
; (supervisorctl/web interface) to work, additional interfaces may be
; added by defining them in separate rpcinterface: sections
[rpcinterface:supervisor]
supervisor.rpcinterface_factory = supervisor.rpcinterface:make_main_rpcinterface
[supervisorctl]
serverurl=unix:///var/run/supervisor.sock ; use a unix:// URL for a unix socket
; The [include] section can just contain the “files” setting. This
; setting can list multiple files (separated by whitespace or
; newlines). It can also contain wildcards. The filenames are
; interpreted as relative to this file. Included files cannot
; include files themselves.
[include]
files = /etc/supervisor/conf.d/*.conf
beaylott
(Ben Aylott)
24
Also check out resin.io … although the use case is slightly different. I have been using it for deploying stripped down emonhub RPI nodes forwarding temperature/humidity data. They are promising to open source a lot of their platfrom in coming months.
