Hi
I just added a feed value to a dashboard. I saved, went to view and got text all across the dashboard.As screen shot
Hi
Could your provide some more info. What version emoncms and dashboard module are you running? Was the dashboard working OK previously? What feed are you trying to add? Does the log file give any clue?
Hi
Local Pi server. Completely up to date, including dashboard modules.
Dashboard was working perfectly. Unfortunately I changed a number of feedvalue widgets at the same time with the result I posted. Nothing untoward in log files. I have created a new dashboard with same information and it works fine. I only reported the error as I have seen there has been some dashboard issues and thought the text details on the screenshot posted may help.
