Hello, I’ve had an Emonpi running for awhile and over time it does not display the daily KWH anymore. What should I do to correct this?
Thanks,Adam
Thanks,Adam
What version are you on?
Go into the administration menu (if you can) click on this button
then simply paste the clipboard here (no further formatting).
There is a known issue around the log filling up after about a month. Can you try a reboot and see if this solves the issue.
Ok, Heres what I found.
Emoncms | Version | low-write 9.9.5 |
Modules | Administration : App v1.2.0 : Backup v1.1.5 : EmonHub Config v1.0.0 : Dashboard v1.3.1 : Device v1.2.0 : EventProcesses : Feed : Graph v1.2.1 : Input : Postprocess v1.0.0 : CoreProcess : Schedule : Network Setup v1.0.0 : sync : Time : User : Visualisation : WiFi v1.3.0 | |
Git URL | GitHub - emoncms/emoncms: Web-app for processing, logging and visualising energy, temperature and other environmental data | |
Git Branch | * stable | |
Buffer | loading… | |
Writer | Daemon is not running, start it at ~/scripts/feedwriter | |
Server | OS | Linux 4.9.35-v7+ |
Host | emonpi emonpi (10.0.1.114) | |
Date | 2019-04-07 14:11:50 UTC | |
Uptime | 14:11:50 up 109 days, 22:40, 0 users, load average: 0.31, 0.20, 0.12 | |
HTTP | Server | Apache/2.4.10 (Raspbian) HTTP/1.1 CGI/1.1 80 |
MySQL | Version | 5.5.57-0+deb8u1 |
Host | 127.0.0.1 (127.0.0.1) | |
Date | 2019-04-07 14:11:50 (UTC 00:00) | |
Stats | Uptime: 9498993 Threads: 2 Questions: 7774312 Slow queries: 5 Opens: 64 Flush tables: 1 Open tables: 57 Queries per second avg: 0.818 | |
Redis | Version | 2.8.17 |
Host | localhost:6379 (127.0.0.1) | |
Size | 152 keys (248.42M) | |
Uptime | 109 days | |
MQTT Server | Version | Mosquitto 1.4.14 |
Host | localhost:1883 (127.0.0.1) | |
Pi | Model | Raspberry Pi 3 Model B Rev 1.2 - 1 GB (Stadium) |
SoC | Broadcom BCM2835 | |
Serial num. | E2BA5333 | |
Temperature | CPU: 48.85°C - GPU: 48.3’C | |
Release | emonSD-26Oct17 | |
File-system | Current: read-only - Set root file-system temporarily to read-write, (default read-only) | |
Memory | RAM | Used: 64.43% Total: 970.93 MB Used: 625.6 MB Free: 345.33 MB |
Disk | Mount | Stats |
/ | Used: 60.96% Total: 3.33 GB Used: 2.03 GB Free: 1.14 GB | |
/boot | Used: 36.30% Total: 59.95 MB Used: 21.76 MB Free: 38.19 MB | |
/home/pi/data | Used: 0.16% Total: 25.47 GB Used: 41.27 MB Free: 24.11 GB | |
PHP | Version | 5.6.30-0+deb8u1 (Zend Version 2.6.0) |
Modules | apache2handler : bcmath : bz2 : calendar : Core v5.6.30-0+deb8u1 : ctype : curl : date v5.6.30-0+deb8u1 : dba : dio v0.0.4RC4 : dom v20031129 : ereg : exif v1.4 $Id: 1c8772f76be691b7b3f77ca31eb788a2abbcefe5 $ : fileinfo v1.0.5 : filter v0.11.0 : ftp : gettext : hash v1.0 : iconv : json v1.3.6 : libxml : mbstring : mcrypt : mhash : mosquitto v0.3.0 : mysql v1.0 : mysqli v0.1 : openssl : pcre : PDO v1.0.4dev : pdo_mysql v1.0.2 : Phar v2.0.2 : posix : readline v5.6.30-0+deb8u1 : redis v2.2.7 : Reflection v$Id: 5f15287237d5f78d75b19c26915aa7bd83dee8b8 $ : session : shmop : SimpleXML v0.1 : soap : sockets : SPL v0.2 : standard v5.6.30-0+deb8u1 : sysvmsg : sysvsem : sysvshm : tokenizer v0.1 : wddx : xml : xmlreader v0.1 : xmlwriter v0.1 : Zend OPcache v7.0.6-devFE : zip v1.12.5 : zlib v2.0 |
HTTP | Browser | Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_6) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/11.1.2 Safari/605.1.15 |
Screen | Resolution | 1680 x 1050 |
Window | Size | 1680 x 989 |
Thanks,Adam.
