Hi there,
I am trying to make a public dashboard for a community solar project. The idea is that it will just be an IP address that can run on a web connected display in a school. However I am struggling a bit with the implementation.
I use a windows machine and have not changed any of the Emoncms code.
The inputs are from a third party logger that I am sending to Emoncms using the write API key.
I have enabled the relevant feed (generation) as public.
I have configured a new dashboard that displays realtime and cumulative generation: Emoncms - user login
From the Emoncms user guide I am not clear on whether I need to build the widget into my own website (which I would rather not do) or if it can be hosted by Emoncms.
If hosted by Emoncms, I don’t know what the URL structure should be.
The threads here:
https://openenergymonitor.org/forum-archive/node/4307.html
https://openenergymonitor.org/forum-archive/node/3594.html
don’t actually spell out what you need to do (to me anyway!).
I would be happy to use the MySolar app if that could simply be made public but again I don’t know how to do it.
Any help appreciated,
Felix
