I have spent a fair bit of time amending how the local MySolarpv app appears, to make it accommodate my gas data instead of the solar data, and various other tweaks to make it more relevant for my gas and electric usage. This was because it displays two sets of Watts in the same graph, and that is what I wanted, and I do not have any solar or other electric feeds. This is the version that comes in the 20Feb2016 emonpi image, apparently using App-9.0.
Nevertheless, I would much prefer to be able to rename this to something like MyDualFuel or similar, so I can restore the MySolarpv back to its normal function again (I took backups!).
However, while I can get My Dualfuel to appear in the App menu dropdown list, and select it, the main page just presents the menu bar and the dark background in the main area and nothing else, and it appears that emoncms does not recognise the path to the Modules/app/mydualfuel directory, or its two mydualfuel files (.html, and .js).
I have added what appears to be a suitable entry in app_menu.php, but it seems something more is needed, and I have been unable to determine what that is. Can anyone suggest some further steps I need to take? There is virtually nothing to describe the relevant procedure to add a new App.
My mydualfuel.html, and mydualfuel.js are copies of the working versions of mysolarpv files, with a simple search and replace to replace âmysolarpvâ with âmydualfuelâ in various variable names, and I expect to do some additional debugging once I get something to display. But clearly something is missing.
