pb66
(Paul)
2
[moved this post here from - Stored feed data wrong - #13 by bart.ellast]
There is a script to help with the conversion in the emoncms/usefulscripts repo
I have never used it and a quick search here on the forum for “phpfiwa_to_phpfina.php” showed 2 posts that had an error with Redis, you could try commenting out the redis test and force a conversion without using redis if it is a problem.
You might find more info using other search terms, there is also the archived forum.
This “Upgrading mysql, timestore, phptimestore feed engines to phpfina and phptimeseries” post might be helpful.
