Hello,
I can’t get my emonpi connected to red_note.
I read a lot but I can’t find out how I would get connected.
Any help is appreciated.
Thanks a lot!
Jos
Hello,
Thanks a lot!
Jos
Hi Jos - did you set up the MQTT node? It will need a Server name and a Username and a Password.
Attach an image of how you have set things up within the MQTT node.
Hi Jon,
I have not setup a mqtt node . I was Thinking it was pre installed .
Can you provide me with a link on how to set up ?
Jos
Are you using an EmonPI, the emonSD image or have you installed it locally?
I was referring to the node-red MQTT node. Double click on the MQTT node-red icon and you should see something like this:
then click on the pencil and send a screenshot.
Hello Brian,
I bought an EmonPi pre installed from the webshop.
Hello Jon,
This are the screenshots.
Ah right - MQTT should be installed
The above looks correct!
And on the Security tab is the Username and Password correct? (sorry I cannot remember the default password at the moment)
EDIT: the default password is: emonpimqtt2016
EDIT2: You can test MQTT via the command line. See MQTT - Guide | OpenEnergyMonitor
Hello Jon,
After changing the password i got connected.
Kind regards,
jos
