What are your emonhub settings for the serialdirect interfacer?
What is the source of the data and which FW?
Try adding a nodeoffset = 11 to the runtimesettings or get the FW to print the node id in the serial output.
The latter is safer if you have any more than one serial/usb connected device.
Dear Paul,
thanks for your reply. In the meantime I found the major fault. The firmware (1.5) was set to csv instead of emonhub.
If someone uses the RPICT4T4 (or similar) I would like to mention that its firmware must set to format = 3 (not 2) according to the wiki.
No, the question is quite often dumb, but what the questioner wanted to know wasn’t.
[Meaning: The way that the question was asked was unclear and left too much in doubt.]
