After adding a AC-coupled battery to my system, I’ve just purchased an emonTXv3. This replaces the emonPi - grid to CT1, battery to CT2 and PV to CT4, and also the AC adaptor.
The emonPi has been moved back inside and a clean 17Oct19 image flashed to the SD (no data migration, so working from a clean base). No sensors are now attached to the Pi, its just acting as a receiver for the emontx and as a local emoncms install. All this work is being done locally.
I’m having an issue where I go to add the Solar Type 2 template to the emontx, but upon creation the new power1 and power4 inputs show “Null”, as well as all 6 feeds created (use, solar, import and *_kWh variants).
I’m not even beginning to look at the battery feed yet - just the grid and PV feeds.
I can see the emontx standard inputs are being received and as expected. I’ve checked the services are all running, and I can see from the emoncms log that the frames are being received and MQTT is publishing values. I’ve also tried uploading directly to emoncms.org but the same issue occurs.
2020-07-09 16:17:42,719 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,0,0,0,0,0,0,0
2020-07-09 16:17:43,150 INFO MQTT Publishing: emonhub/rx/15/values 677,240.96,23,97,0,177,4294967257,4294967223,0,791,300,300,300,1,-62
2020-07-09 16:17:47,753 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,0,0,0,0,0,0,0
2020-07-09 16:17:52,835 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,0,0,0,0,0,0,0
2020-07-09 16:17:53,082 INFO MQTT Publishing: emonhub/rx/15/values 678,241.48000000000002,25,94,0,178,4294967257,4294967223,0,791,300,300,300,1,-61
2020-07-09 16:17:55,166 INFO emoncmsorg sending: https://emoncms.org/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1594307847.5859709,5,0,0,0,0,0,0,0,0,0,0,0],[1594307852.542232,5,0,0,0,0,0,0,0,0,0,0,0],[1594307852.9767327,15,676,240.61,21,100,0,176,4294967257,4294967223,0,790,300,300,300,1,-62],[1594307857.6278937,5,0,0,0,0,0,0,0,0,0,0,0],[1594307862.5989897,5,0,0,0,0,0,0,0,0,0,0,0],[1594307862.9287384,15,677,240.96,23,97,0,177,4294967257,4294967223,0,791,300,300,300,1,-62],[1594307867.6097615,5,0,0,0,0,0,0,0,0,0,0,0],[1594307872.5762782,5,0,0,0,0,0,0,0,0,0,0,0],[1594307872.819719,15,678,241.48000000000002,25,94,0,178,4294967257,4294967223,0,791,300,300,300,1,-61]]&sentat=1594307875
2020-07-09 16:17:57,668 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,0,0,0,0,0,0,0
2020-07-09 16:18:02,752 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,0,0,0,0,0,0,0
2020-07-09 16:18:02,988 INFO MQTT Publishing: emonhub/rx/15/values 679,241.44,25,95,0,176,4294967257,4294967224,0,792,300,300,300,1,-62
2020-07-09 16:18:07,859 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,0,0,0,0,0,0,0
2020-07-09 16:18:12,723 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,0,0,0,0,0,0,0
2020-07-09 16:18:12,963 INFO MQTT Publishing: emonhub/rx/15/values 680,241.06,24,100,0,174,4294967257,4294967224,0,792,300,300,300,1,-62
2020-07-09 16:18:17,862 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,0,0,0,0,0,0,0
2020-07-09 16:18:22,711 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,0,0,0,0,0,0,0
2020-07-09 16:18:22,947 INFO MQTT Publishing: emonhub/rx/15/values 681,241.01,24,103,0,168,4294967257,4294967224,0,792,300,300,300,1,-62
2020-07-09 16:18:25,606 INFO emoncmsorg sending: https://emoncms.org/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1594307877.580837,5,0,0,0,0,0,0,0,0,0,0,0],[1594307882.6446295,5,0,0,0,0,0,0,0,0,0,0,0],[1594307882.7660952,15,679,241.44,25,95,0,176,4294967257,4294967224,0,792,300,300,300,1,-62],[1594307887.6525965,5,0,0,0,0,0,0,0,0,0,0,0],[1594307892.6174607,5,0,0,0,0,0,0,0,0,0,0,0],[1594307892.746738,15,680,241.06,24,100,0,174,4294967257,4294967224,0,792,300,300,300,1,-62],[1594307897.5990968,5,0,0,0,0,0,0,0,0,0,0,0],[1594307902.5738735,5,0,0,0,0,0,0,0,0,0,0,0],[1594307902.7137234,15,681,241.01,24,103,0,168,4294967257,4294967224,0,792,300,300,300,1,-62]]&sentat=1594307905
2020-07-09 16:18:27,818 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,0,0,0,0,0,0,0
2020-07-09 16:18:32,785 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,0,0,0,0,0,0,0
2020-07-09 16:18:33,040 INFO MQTT Publishing: emonhub/rx/15/values 682,240.73000000000002,30,103,0,161,4294967257,4294967224,0,793,300,300,300,1,-62
2020-07-09 16:18:37,727 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,0,0,0,0,0,0,0
2020-07-09 16:18:42,820 INFO MQTT Publishing: emonhub/rx/15/values 683,240.78,23,121,0,153,4294967257,4294967225,0,793,300,300,300,1,-62
2020-07-09 16:18:43,055 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,0,0,0,0,0,0,0
2020-07-09 16:18:47,835 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,0,0,0,0,0,0,0
2020-07-09 16:18:52,721 INFO MQTT Publishing: emonhub/rx/15/values 684,240.89000000000001,20,134,0,144,4294967257,4294967225,0,794,300,300,300,1,-62
2020-07-09 16:18:52,842 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,0,0,0,0,0,0,0
2020-07-09 16:18:55,972 INFO emoncmsorg sending: https://emoncms.org/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1594307907.568572,5,0,0,0,0,0,0,0,0,0,0,0],[1594307912.631566,5,0,0,0,0,0,0,0,0,0,0,0],[1594307912.7516453,15,682,240.73000000000002,30,103,0,161,4294967257,4294967224,0,793,300,300,300,1,-62],[1594307917.6096344,5,0,0,0,0,0,0,0,0,0,0,0],[1594307922.570212,15,683,240.78,23,121,0,153,4294967257,4294967225,0,793,300,300,300,1,-62],[1594307922.6811507,5,0,0,0,0,0,0,0,0,0,0,0],[1594307927.636699,5,0,0,0,0,0,0,0,0,0,0,0],[1594307932.521761,15,684,240.89000000000001,20,134,0,144,4294967257,4294967225,0,794,300,300,300,1,-62],[1594307932.7320032,5,0,0,0,0,0,0,0,0,0,0,0]]&sentat=1594307935
2020-07-09 16:18:57,934 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,0,0,0,0,0,0,0
2020-07-09 16:19:02,685 INFO MQTT Publishing: emonhub/rx/15/values 685,241.01,17,145,0,135,4294967257,4294967226,0,794,300,300,300,1,-61
2020-07-09 16:19:02,927 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,0,0,0,0,0,0,0
2020-07-09 16:19:07,909 INFO MQTT Publishing: emonhub/rx/5/values 0,0,0,0,0,0,0,0,0,0,0
