Hello and good evening
i want to ask about the coding…
the problem i faced rightnow is the current value. when connecting to IoT platform, the value of the current is always zero. but when i compile the sketch without the IoT coding, it can reading the value of current. what is the problem actually?
here is my coding with the IoT… the IoT plateform i use is ThingSpeak
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ThingSpeak.h>
#include"EmonLib.h"
EnergyMonitor emon1;;
int Power;
int energy;
float total, kWhUsed;
float TotalkWhUsed;
const char* ssid = "Redmi3s";
const char* password = "xxxxxxxxxxx";
WiFiClient client;
unsigned long myChannelNumber = 470287;
const char * myWriteAPIKey = "XXXXXXXXXXXXXXXX";
uint8_t Irms, power, totalkWhUsed, k=0, l=0, m=0;
void setup()
Serial.begin(115200);
delay(10);
// Connect to WiFi network
Serial.println();
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED)
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
// Print the IP address
Serial.println(WiFi.localIP());
ThingSpeak.begin(client);
void loop()
static boolean data_state = false;
long milisec = millis();
long time = milisec/1000;
double Irms = emon1.calcIrms(1480); // Calculate Irms only
power = (Irms*240.0); // Apparent power
totalkWhUsed = ((power*time))/(3600); //TotalkWhUsed = TotalkWhUsed + kWhUsed;
Serial.print("Irms ");
Serial.println(Irms); // Irms
delay(2000);
Serial.print("power ");
Serial.println(Power);
delay(2000);
Serial.print("totalkWhUsed ");
Serial.println(totalkWhUsed);
Serial.print("\n\n");
delay(2000);
k=Irms;
l=power;
m=totalkWhUsed;
// Write to ThingSpeak. There are up to 8 fields in a channel, allowing you to store up to 8 different
// pieces of information in a channel. Here, we write to field 1.
if( data_state )
ThingSpeak.writeField(myChannelNumber, 1, k, myWriteAPIKey);
ThingSpeak.writeField(myChannelNumber, 2, l, myWriteAPIKey);
data_state = false;
else
ThingSpeak.writeField(myChannelNumber, 3, m, myWriteAPIKey);
data_state = true;
delay(1000); // ThingSpeak will only accept updates every 15 seconds.
