The next release of the firmware has tools to do that from the app, but for curent releases, you would need to delete the files manually using another computer.:
  • Power down the IoTaWatt
  • Open it up and remove the SD card
  • Mount the SD in another computer and delete iotawatt/iotalog.log
  • Reinsert the card in IoTaWatt
  • Restart the IoTaWatt
It will create a new log.
Because the file is open and being written frequently, you can damage the file system by deleteing while IoTaWatt is running. The new tools will close and delete the file and restart the ioTaWatt in one operation.
The current card can easily hold the maximum size datafile - 15 years. It’s explained here
