I have four SCT-013-030 - which have a built in burden resistor and give a an output of 0 to 1v.
My question is about this circuit. Since the article doesn’t explain what purpose the components serve
- Do I need a voltage divider with my CT clamp? If it only outputs 0-1v, it doesn’t seem like I would need a voltage divider…
- What purpose does the capacitor serve?
I’m using an ESP8266 (3.3v logic) and I have a fixed voltage value of 122.1, which is what I measured from my wall outlet.
I did some test readings wiring up the CT directly to the analog input of my arduino and with a calibration value of 49, the emonlib is showing the correct wattage for 60w, 72w, 132w and 750w resistive loads I have put on the circuit.
49 is just a calibration number I narrowed in on by trial and error, but the output results seem to be correct.
