I have brought 100 off temp sensors with 1M fly leads with 2.54mm plug on the end for my BMSs, they are 10K 3950 that will suit my LTO batteries, I have then noticed that the earlier version boards that i have use a 10K 4150, I didn’t realise this until I try them on the version 4.21, this there a way to change the setting in visual studio?, I have notice that in the start of visual studio there is a listing of each ext temp for each version, can i edit this and reflash to the 3950 temp sensor?
[env:V421]
; 20 balance resistors marked 6R2 (6.2ohm)
build_flags=-DDIYBMSMODULEVERSION=421 -DMV_PER_ADC=2.00 -DINT_BCOEFFICIENT=4050 -DEXT_BCOEFFICIENT=4150 -DLOAD_RESISTANCE=4.96 -DBAUD=2400
