Not necessarily. You can either just use a publish to MQTT process on the second value in emoncms, just as I suggested above for the summed value, that would work with either MQTT or HTTP from the emonesp (I am assuming you already have that working and posting to the local emonpi) or if using MQTT to post to the local emonPi, then you can still “tap into” that MQTT topic in the same way as if it was from emonhub, I just am not sure what the topic would be offhand, but it should be obvious from the config page of the emonesp.
The bottom line is that by editing the emonPiLCD.cfg you should be able touse any value from an existing MQTT topic (on the same MQTT server) whether it be from emonhub or an emonesp, or alternatively, if there isn’t an existing topic, create one using a “publish to mqtt” input process in emoncms, that should cover most situations.
