gjwo
(Graham Wood)
1
I can’t get the MQTT message format right so that emoncms accepts the inputs.
This is my emon build configuration:
This is what the log is telling me
These are the topic tags I am using
/emon/PMon10/Apparent/Outside_Lighting
/emon/PMon10/Power/Outside_Lighting
/emon/PMon10/Apparent/Downstairs_Lighting
/emon/PMon10/Power/Downstairs_Lighting
/emon/PMon10/Apparent/Extension_Lighting
/emon/PMon10/Power/Extension_Lighting
/emon/PMon10/Apparent/Cooker
/emon/PMon10/Power/Cooker
/emon/PMon10/Voltage
/emon/PMon10/Apparent/Kitchen_Plugs
/emon/PMon10/Power/Kitchen_Plugs
/emon/PMon10/Apparent/Outside_Plugs
The data consists a single numeric value per message
Any help would be gratefully received
gjwo
(Graham Wood)
2
Also tried with topics like
/emon/PMon10/Kitchen_Plugs/RealPower
/emon/PMon10/Outside_Plugs/ApparentPower
/emon/PMon10/Outside_Plugs/RealPower
/emon/PMon10/Lounge_End_Plugs/ApparentPower
/emon/PMon10/Lounge_End_Plugs/RealPower
/emon/PMon10/Whole_House/ApparentPower
/emon/PMon10/Whole_House/RealPower
/emon/PMon10/Upstairs_Lighting/ApparentPower
/emon/PMon10/Upstairs_Lighting/RealPower
/emon/PMon10/Outside_Lighting/ApparentPower
/emon/PMon10/Outside_Lighting/RealPower
/emon/PMon10/Downstairs_Lighting/ApparentPower
/emon/PMon10/Downstairs_Lighting/RealPower
/emon/PMon10/Extension_Lighting/ApparentPower
/emon/PMon10/Extension_Lighting/RealPower
/emon/PMon10/Cooker/ApparentPower
/emon/PMon10/Cooker/RealPower
/emon/PMon10/Kitchen_Plugs/ApparentPower
gjwo
(Graham Wood)
3
does the topic need a trailing “/” ?
gjwo
(Graham Wood)
4
More information, in the trace below the I have added quotes around the topic and the data strings (these don’t appear in the messages to the MQTT broker…
PowerDataProcessor Connected
'/emon/PMon10/Voltage '‘237.935’
'/emon/PMon10/Kitchen_Plugs/ApparentPower '‘14.534’
‘/emon/PMon10/Kitchen_Plugs/RealPower ‘’-0.312’
'/emon/PMon10/Outside_Plugs/ApparentPower '‘10.097’
‘/emon/PMon10/Outside_Plugs/RealPower ‘’-1.512’
'/emon/PMon10/Lounge_End_Plugs/ApparentPower '‘10.634’
'/emon/PMon10/Lounge_End_Plugs/RealPower '‘0.998’
'/emon/PMon10/Whole_House/ApparentPower '‘34.300’
'/emon/PMon10/Whole_House/RealPower '‘0.580’
'/emon/PMon10/Upstairs_Lighting/ApparentPower '‘1.141’
‘/emon/PMon10/Upstairs_Lighting/RealPower ‘’-0.202’
'/emon/PMon10/Outside_Lighting/ApparentPower '‘1.552’
‘/emon/PMon10/Outside_Lighting/RealPower ‘’-0.168’
'/emon/PMon10/Downstairs_Lighting/ApparentPower '‘0.667’
'/emon/PMon10/Downstairs_Lighting/RealPower '‘0.143’
'/emon/PMon10/Extension_Lighting/ApparentPower '‘0.879’
'/emon/PMon10/Extension_Lighting/RealPower '‘0.132’
'/emon/PMon10/Cooker/ApparentPower '‘15.129’
‘/emon/PMon10/Cooker/RealPower ‘’-2.091’
'/emon/PMon10/Voltage '‘238.432’
'/emon/PMon10/Kitchen_Plugs/ApparentPower '‘12.595’
'/emon/PMon10/Kitchen_Plugs/RealPower '‘0.097’
'/emon/PMon10/Outside_Plugs/ApparentPower '‘10.184’
‘/emon/PMon10/Outside_Plugs/RealPower ‘’-0.698’
'/emon/PMon10/Lounge_End_Plugs/ApparentPower '‘10.127’
'/emon/PMon10/Lounge_End_Plugs/RealPower '‘1.485’
'/emon/PMon10/Whole_House/ApparentPower '‘43.681’
'/emon/PMon10/Whole_House/RealPower '‘0.986’
'/emon/PMon10/Upstairs_Lighting/ApparentPower '‘1.332’
‘/emon/PMon10/Upstairs_Lighting/RealPower ‘’-0.335’
'/emon/PMon10/Outside_Lighting/ApparentPower '‘1.268’
‘/emon/PMon10/Outside_Lighting/RealPower ‘’-0.132’
'/emon/PMon10/Downstairs_Lighting/ApparentPower '‘1.113’
'/emon/PMon10/Downstairs_Lighting/RealPower '‘0.052’
'/emon/PMon10/Extension_Lighting/ApparentPower '‘0.988’
'/emon/PMon10/Extension_Lighting/RealPower '‘0.060’
'/emon/PMon10/Cooker/ApparentPower '‘14.464’
‘/emon/PMon10/Cooker/RealPower ‘’-1.879’
Does this look OK or have I misunderstood the required message format?
gjwo
(Graham Wood)
5
OK I had misunderstood the format, this seems to be sent without causing the errors logged above (ignore quote marks)
‘emon/PMon10/Whole_House’‘Voltage 238.970’
‘emon/PMon10/Kitchen_Plugs’‘ApparentPower 19.951’
‘emon/PMon10/Kitchen_Plugs’‘RealPower 0.580’
‘emon/PMon10/Outside_Plugs’‘ApparentPower 10.113’
‘emon/PMon10/Outside_Plugs’‘RealPower 0.176’
‘emon/PMon10/Lounge_End_Plugs’‘ApparentPower 14.590’
‘emon/PMon10/Lounge_End_Plugs’‘RealPower -0.894’
‘emon/PMon10/Whole_House’‘ApparentPower 44.137’
‘emon/PMon10/Whole_House’‘RealPower -1.185’
‘emon/PMon10/Upstairs_Lighting’‘ApparentPower 1.259’
‘emon/PMon10/Upstairs_Lighting’‘RealPower -0.351’
‘emon/PMon10/Outside_Lighting’‘ApparentPower 2.694’
‘emon/PMon10/Outside_Lighting’‘RealPower 0.132’
‘emon/PMon10/Downstairs_Lighting’‘ApparentPower 1.215’
‘emon/PMon10/Downstairs_Lighting’‘RealPower -0.010’
‘emon/PMon10/Extension_Lighting’‘ApparentPower 1.577’
‘emon/PMon10/Extension_Lighting’‘RealPower -0.048’
‘emon/PMon10/Cooker’‘ApparentPower 17.436’
‘emon/PMon10/Cooker’‘RealPower -1.075’
‘emon/PMon10/Whole_House’‘Voltage 238.695’
so to summarise:
- List item topic with no leading or trailing “/” or " "
- List item payload data with no leading or trailing " ": key value
