I had running a script which created a load of wrong inputs. Now I am trying to delete them with https://emoncms.org/input/delete?id=nnn&apikey=xxxx
but I always get
Input module: Page not found. Back to input/view
will delete all inputs that have no process list in a single call, to preserve any inputs that you wish to keep but do not currently have a processlist, you can add a simple “scale” or “reset to zero” process so it isn’t cleaned (deleted) as deleted inputs will recreate with a higher inputid and throw out the viewed order. For example if you have a node with inputs 1, 2 and 3, if only 2 has no process list and you run “clean”, input 2 will be deleted and recreated on the next posting, but when viewed on the inputs page the order will be 1, 3, 2 because 2 has a higher inputid.
