Hi all
Local install of Emoncms Low Write 9.8.4: 2017.05.01
Release emonSD-07Nov16.
Running on RPi2 with RFM69Pi module (EmonBase installation)
Nodes are correctly reported on the Input page and the values are being updated
But the feed page just shows a spinning sundial…??? even after a reboot or power down.
On the Input page, under Process List it shows “wait…” for the feeds that I created at the start but after a reboot to get the correct local time, it now just shows "wait… for those inputs.
Emoncms.log last entries
2017-05-13 07:08:22.853|WARN|phpmqtt_input.php|Connecting to MQTT server: Connection Accepted.: code: 0
2017-05-13 07:08:22.855|WARN|phpmqtt_input.php|Subscribed to topic: emon/#
2017-05-13 07:10:00.107|ERROR|feed_model.php|EngineClass() Engine id ‘1’ is not supported.
2017-05-13 07:10:00.421|ERROR|feed_model.php|EngineClass() Engine id ‘1’ is not supported.
2017-05-13 07:10:04.477|ERROR|feed_model.php|EngineClass() Engine id ‘1’ is not supported.
2017-05-13 07:10:06.621|ERROR|feed_model.php|EngineClass() Engine id ‘1’ is not supported.
2017-05-13 07:10:07.081|ERROR|feed_model.php|EngineClass() Engine id ‘1’ is not supported.
2017-05-13 07:10:11.649|ERROR|feed_model.php|EngineClass() Engine id ‘1’ is not supported.
2017-05-13 07:10:16.172|ERROR|feed_model.php|EngineClass() Engine id ‘1’ is not supported.
2017-05-13 07:10:16.971|ERROR|feed_model.php|EngineClass() Engine id ‘1’ is not supported.
2017-05-13 07:10:20.064|ERROR|feed_model.php|EngineClass() Engine id ‘1’ is not supported.
I have re-flash the SD card many times with Win32Diskmanager and also with Etcher, no change.
A few people have reported this “ERROR|feed_model.php|EngineClass() Engine id ‘1’ is not supported.”
but I never understood how they manage to fix the problem other then re-flashing the SD card, but that did not work for me.
I am starting from scratch and do not need to use any old date or feeds.
Spend most of last week on this problem and got no-where so any support, suggestions, help or pointers would be greatly appreciated
