Roblister
(Robert Lister)
5
Run update from the emoncms menu? Or try and SSH in?
I have just flashed another SD card. If I leave it after powerup then I wont know if its had the same error reading from Github. I only see that after creating account and logging in.
Thank’s for your invaluble help and patience.
Update:
After leaving it for nearly an hour accepted ethernet and created an account. Checked the update log and had that same error message old or undefined image etc. Now started Full Update which seems to be progressing.
Not touched wifi yet. I am hoping that is not another can of worms as last time I tried I was communicating on wifi despite wifi config giving a disconnected status.
Further update:
I seem to have got it running. It looks like a lot of the problem was not finishing the updates.
Not sure about the wifi. That seems to be working with ethernet removed. But it shows as disconnected still which doesnt make sense.
Connection Info
Status: Disconnected
IP Address: 192.168.0.43
Mac Address: b8:27:eb:12:3e:8c
Sub Net Mask: 255.255.255.0
Rx Packets:
Tx Packets:
Rx Bytes: 223898 (218.6 KiB)
Tx Bytes:
