Good morning.
I am using an emontx3 and an emoncms
I have just downloaded the newest emonpi image and flashed it to the SD card, I believe correctly…
However when I try and create new feeds for local recording from the inputs, which I can see updating, I get the error…Feed could not be created, undefined.
The emoncms log shows the following…
What can be done please?
Regards
Chris
2016-06-11 10:23:05.623|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2016-06-11 10:23:15.607|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2016-06-11 10:23:34.882|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2016-06-11 10:30:19.126|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2016-06-11 10:30:24.633|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2016-06-11 10:30:45.901|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2016-06-11 10:30:45.966|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2016-06-11 10:30:52.164|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2016-06-11 10:30:52.228|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2016-06-11 10:35:32.727|WARN|phpmqtt_input.php|Starting MQTT Input script
2016-06-11 10:35:33.847|WARN|phpmqtt_input.php|Subscribing to: emon/#
2016-06-11 10:35:33.848|WARN|phpmqtt_input.php|Not connected, retrying connection
2016-06-11 10:35:33.849|WARN|phpmqtt_input.php|Connecting to MQTT server: Connection Accepted.: code: 0
2016-06-11 10:35:33.849|WARN|phpmqtt_input.php|Subscribed to topic: emon/#
2016-06-11 10:36:01.814|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2016-06-11 10:36:08.214|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2016-06-11 10:36:13.785|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2016-06-11 10:36:18.158|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2016-06-11 10:36:23.362|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2016-06-11 10:36:50.765|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2016-06-11 10:36:54.741|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2016-06-11 10:37:57.817|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2016-06-11 10:38:21.337|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2016-06-11 10:38:27.124|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2016-06-11 10:38:33.084|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2016-06-11 10:38:38.338|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2016-06-11 10:38:42.892|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2016-06-11 10:38:48.268|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2016-06-11 10:39:50.053|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
