Its been a little while since i used my emon pi, I just moved into a new flat thought id set it up again, but i cannot seem to connect to it. when i connect an ethernet cable it does display the ethernet address, but i cannot seem to connect to it, i even tried pinging the IP address which doesnt seem to work
There is a good chance the network is not quite right because you have moved.
If you have not used it for a while, them I suggest you download a new version of the image, open the EmonPi up and re-flash the SD Card.
You will then have an up to date version and it should connect to the network.
