Just installed a NTC 10k 3950 thermistor on one of my cell modules and the temp reading is way off. It’s reading 60-90 degrees Celsius. At the same time the “internal” temp reading shows 24 degrees Celsius. So the external one should be reading just a couple degrees lower but instead is showing 60-90…
Is there a way to calibrate the the thermistor in the diybms dashboard or in the code in visual studio?
I’ve tried Changing the coefficient option in the diybms dashboard but that didn’t seem to make any difference.
And I realize I can just purchase the recommended thermistor but I have a ton of these on hand and I would like to use them if possible.
Here is the model and specs of the ntc thermistor I’m using. When I purchased them it said they were 3950k but the data sheet shows 3380k.
MF58103F3380
Resistance in Ohms @ 25°C - 10k
Resistance Tolerance: ±1%
B25/50 - 3380K
Operating Temperature -55°C ~ 200°C
