Calculating the correct Voltage Output CT
Thanks for the reply.
Yes, sorry, it’s range is 0V to Vref.
I can’t quite get my head around this.
OK, that I can follow - thanks :slight_smile:
The input voltage (5v on this diagram, that I’m using for reference) will be 3.3v. I mentioned it for completeness, I don’t believe it has any impact on the calculation that lead you to 389mV rms.
