i have knocked my head on something and got an idea for the outdoor pool
if i add 2 temp sensor to the solar mat (for inlet and outlet) and a flow sensor (hall effect type) would it be possible in emoncms to display how much energy is added and maybe predict when the inlet will reach a certain temp if system knows how many liters the pool is?
still planning the hardware side, need to control 2 pumps, one high flowrate for the pool and a low flow one for the solar side of things
dont axe me, it was just another crazy thought
Is it something like this, that you have in mind?
https://heatpumpmonitor.org/
not sure, i would not call it a heat pump, but i guess you can call it that
the solar mat is one of these
you just place it in the sun and pump water through slowly to get max heat from the sun
i saw an youtube video where they said that if you know the flow rate and the temp gained you could figure how much energy is added, sadly they did not tell how to calculate
the pool itself is one of these
the pump i will use for the solar mat is the one shown in front of the pool
i just added a surface skimmer and the flow rate of the pump is now a joke, but is plenty for a seperate solar heating circuit
that is the flow sensor, it can handle the flow rate with a little to spare
for temp sensors sealed ds18b20’s would do
i just need to design and 3d print some adapters as the pool hose’s are 32mm and the flow sensor is 1/2" inch bsb
i guess it can be called a heat pump since it transfers heat from one medium to the other, here its air to water
i just normally think of a heat pump as a big unit that uses loads of electricity to get heat
of course here i use little electricity for the pump to circulate the water
will think of it before i sleep
Hmm, one of these?
or perhaps this?
:wink: :grinning:
It’s doing exactly what a heat pump does, but probably on a smaller scale, so in principle the heat pump monitor will do what you want.
the person sized one could be used as a heater if adding water cooling loop to it
but i missed an Z, first post corrected :smiley:
shit happens when you are getting tired
yes, that is what came to mind, my head does not work as fast when its getting late
but yes, i guess it can do that, but do i need a CT for it? or can i read the watt usage and enter a fixed number?
and can i predict how long it will take to heat the pool to say 30C ?
You’re an hour east of me, and many hours east of Bill. Don’t worry about the missing ‘z’.
Just go and get some more. ZZZzzzz… :sleepy:
That, forgetting losses, is pure physics. So Wikipedia is where you go. If somebody complains to me that their electric shower isn’t working properly, this is what I use:
Power (kW) = Flow Rate (l/s) × Temp.Rise (°C) × 4.2
Why might you need a c.t? That’s only needed if you’re interested in efficiency.
I’d say that would be extremely difficult, because the losses will depend on the air temperature, wind speed and the surface areas - which will lose heat at different rates depending on whether it’s the water surface, the pool sides or pool bottom. And if the losses equate to the heat input at a temperature less than 30°C, that’s the top temperature you can reach.
will do, just finished setting up emoncms on the empty web space i have with my hosting company. closed down a small 3d print shop and the server is paid for rest of year.
what i will me thinkering about during the night and tomorrow is the hardware side of things,
something based on this: WiFi MQTT Control Relay Thermostat - Guide | OpenEnergyMonitor (or something self made with the ESP8266, i just need to figure about nodered and mqtt, not sure if the hosting company has those, if so i could live without a pi
or do i not think straight?
Sorry, I know nothing about MQTT and Nodered, so I can’t help you there.
it does not have to be super precise, a cloud could pass in front of the sun and scew up things
you are right, and i would also need an ac adapter (i think) but it could be fun to see how well it works. if anything i could add it last on the build list
you are right, so far we only have a black cover on top of it, i do plan to get a solar blanket for it which is just bubble wrap cut in a big circle shape
and if all goes to plan next summer we should be house owners and then the pool will be on a raised platform so it can be insulated on the sides and under it, more planning for that during the winter
but if that happens would it help things if i add sensors at the sides and bottom, under the insulation and on the outside of the insulation?
anyways i think its time for a lot of that ZZZzzzz… :sleepy:
Just givin’ ya a friendly ribbing about it, Bo. :wink:
Bonus points if you know what the item in the first picture is and who is standing beside it.
More if you know what the animal in the second picture is. :grin:
Is that Robin Williams next to that Cray-1?
cray super computer and Seymour Cray next to it
Yep. The animal in the next pic?
crayfish?
tempted to say lobster, but do not quite fit with how i remember a lobster, seems to small to be a lobster as i remember it
Crayfish. You’re right about the looks though. They do indeed look like a miniature Lobster.
