I am new to this project so please excuse me if these questions are not new.
I recently installed PlatformIO on Visual Studio Code on a Windows 10 laptop. I downloaded the latest code for the ESP8266 legacy V4 software. I opened the provided workspace and tried to build the EspController project. I am using Espressif8266 version 2.6.3 as I got errors on other projects with the latest version 3.x.x.
The following errors popped up.
Well, it looks like this version of the compiler does not support C++17 !
BTW, you can multiple versions of the framework in parallel.
Just specify which version you want in the ini file.
Hi Fred
I used the INI file as is. So I did not select anything else. I thought that it might work “out of the box” if I used what was supplied.
I did change the compiler version but then a heap of other problems pop up. I am using the version 2.6.3 of the framework.
I tried the ESP32 version of the code and that compiles first time with no issues.
