I tried 2 things in the last few days:
First, I found that the 2A power supply doesn’t give enough power since lots of
Under-voltage detected! (0x00050005)
in dmesg. I replaced it with a 3A version and that doesn’t happen anymore.
Second, I replaced the bluetooth adapter with a new one. It didn’t help at first. I got 104 messages with
[Wed Jun 16 11:12:07 2021] Bluetooth: hci0: link tx timeout
[Wed Jun 16 11:12:07 2021] Bluetooth: hci0: killing stalled connection 00:80:25:21:55:8d
but after 27 hours uptime, suddenly I got readings form my inverter again after being broken for 16 days. The log message I posted is the last error I have seen.
I have no idea what has suddenly changed at 11:12 UTC (actually 12:12 my time), just as I don’t have any idea why it stopped working.
I’m going to use a USB extension lead to bring the USB-dongle a bit further away from wiring and hopefully make the connection more reliable. I can only think of a signal strength or signal/noise ratio issue.
So I’m marking this as solved.
