pb66
(Paul)
20
Yes it was, the folder was renamed from backup/backup to backup/backup-module so I suspect there was no accompanying addition made to the updater script to change the existing symlinks perhaps (I haven’t checked)
I believe this has been done to try and get the non-www modules to a more consistent structure, it looks like the post-process and sync modules have had the same treatment too (so those symlinks maybe red too?).
Looking closer at the commit for the change to the folder name, it also seems to add a warning in the GUI when the config file is missing, so once the symlink is fixed, there should be some info about the config file in the GUI.
